    Feb 2009
    telford
    2,090
    33
    cabinet door seals
    Hi just changed some seals on a double door commercial cabinet had to have them tailor made as this thing had no id numbers,they are the magnetic type the problem I have one door is fine it holds shut the other appears to be weak? any pointers to what may be the problem the doors are approx one metre x point three.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: cabinet door seals
    Is the door frame parallel to the cabinet? this can cause the problem.
    Feb 2008
    502
    have you tried heating them up with a hairdryer and pulling them out to stretch themout
    3,853
    Seem to remember reading that it can take a while for the magnets to work in door seals, maybe the old one was the opposite way round with regard to the north and south poles, I had one do the same and not really hold the door shut, think we propped it shut with a 20L oil drum overnight and i never heard back so assume all was ok the next day.
    manchester
    5,639
    are the doors spring loaded, maybe increase tension to help compress the seal
    foster always send out door gaskets folded up so theyre crap when u fit em
    ireland
    1,452
    They can take time to bed in, i tell customers up to a week and they must firmly push doors closed, magnets seem to be weaker on replacements
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by martinw58 View Post
    And lube the hinge side door seal with a smear of Vaseline. Reduces friction when closing.
    Dec 2008
    77
    137
    Quote Originally Posted by mikeref View Post
    Do you know the make of cabinet
    Dec 2010
    devon
    837
    Mike u still talking about door seals or is my personal life back on the net again?
    Feb 2009
    telford
    2,090
    33
    Quote Originally Posted by doormaster2008 View Post
    It's badged domino,one door is fine
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by charlie patt View Post
    Welp, a smear of lubricant prevents a lot of problems. ( view post # 7) Friction and chafing causes the rubber to fail sooner then expected.
    Personal life? Dunno what you mean.
