Results 1 to 15 of 15
    Mar 2015
    United Kingdom
    2
    Interview written test
    Hi i've got an interview next week with an A/C company the first part of the inverview is a written test and i've got no idea what to expect? They've told me to swat up on vrv's and refrigeration knowledge. My theory is ok but got no idea what they'll ask about vrv's.
    Feb 2007
    2,473
    Re: Interview written test
    What 3 tasks during the install/commissioning are the most important to ensure a long and trouble free lifespan of the system? Why?
    What is the difference between a 2 pipe and a 3 pipe system?
    What is the function of a MCU/BC/MC box?
    How many MCU/BC/MC boxes would you expect to find on a 2 pipe system?
    For an engineer, what is the most important difference between mineral and synthetic oil? Why is synthetic oil used?
    When does the (VRV/VRF) outdoor unit work the hardest? All idu in cooling, all idu in heating or half n' half?
    What is the difference between HR and HP?
    What is the main reason to choose a 3 pipe system over a 2 pipe system?
    Why when we mentioned 2 & 3 pipe systems above does Mitsubishi Electric's City Multi systems not follow the same theories? How is this achieved?
    Describe how you would replace an idu's EEV.
    Describe how you would replace a compressor.
    In heating the system is running with a discharge temperature of 98ºC, why would this be? If this is allowed to continue what is the likely outcome?
    After you achieved a 8000 micron vacuum and isolated the vacuum pump, the gauge is slowly rising. Give 3 reasons why this might happen.
    How can you determine which of the 3 reasons above is the culprit?
    OK,
    That's the type of questions I would ask.
    If you do know what brands you would be working on then the questions can obviously be more targeted.
    Good Luck!
    Mar 2015
    United Kingdom
    2
    they mostly work with daikin and mitsubishi i belive, thanks a lot.
    Oct 2008
    newbury
    1,444
    OK,
    Good Luck!
    I just failed the interview..
    70
    4,702
    47
    Me too!
    Feb 2007
    2,473
    Hang on,
    I didn't write it in swedish, did I? ???
    5,667
    Makes sense to me ��
    Good questions Viking
    3,853
    There may be some health and safety type questions too, would be worth refreshing yourself on ppe and method statements etc
    manchester
    5,639
    difference between a 2 pipe and a 3 pipe is an extra pipe
    Feb 2009
    telford
    2,090
    33
    And the difference between a 2 pipe system a 3 pipe system is 1 less pipe
    38
    You and me Grizzly
    Think I will stick with ammonia.
    But seriously, good that employers are screening job applicants with actual tests for system knowledge. Here we have a 3 month test/ proving period before full employment. If they don't cut the mustard then see you by.
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Magoo
    I am with you and Grizzly I will stay with the industrial stuff. It's the same in Australia, 3 month probationary period, if you can't it from the head to the hands then no matter how well you do in a written test you will struggle on site.
    BTW I failed Vikings test as well.
    Paul
    Born to fish, forced to work
    Feb 2007
    2,473
    Hmm,
    So many respected members stating they would fail...
    Let me clarify,
    To me the written test on it's own is not a pass or fail, it is about what else it tell me.
    - Can you read and write, will I be able to read your service reports?
    - Is the claims you made in your CV backed up by knowledge or did you just google it?
    - Are you able to verbally argue for your viewpoints during the interview?
    So if your CV tell me that you worked as a VRV/VRF system specialist for the last 10 years and you don't know that a 3 pipe system (Heat Recovery-HR) are able to provide simultaneous heating/cooling whilst the 2 pipe system (Heat Pump-HP) does one or the other for the whole system... Yes, then you failed.
    But if you on the other hand didn't state in your CV that you had extensive VRV/VRF experience then that lack of knowledge would not be held against you.
    BTW,
    Not even my answers to those questions might be the "right" ones but you will get a good argument about it afterwards.
    Croatia
    68
    2,261
    Hi, I failed too
    anyhow I'll stick with ammonia too, Magoo do you need some apprentice ..
    Best regards, Josip
    Aug 2007
    Adelaide Australia
    70
    562
    Hi Viking
    Of course you are right different people have a different knowledge base, I think some of us took the simplistic view, I am pretty sure we all knew what you were getting at.
    I certainly know very little about VRV/VRF systems as I never work on them so I would never include anything about them on my CV and because of that I would never apply for an A/C job.
    Appropriate interview questions are always a good way of determining if the persons knowledge matches their stated claims, best thing is to be truthful on your CV.
    Paul
