    Fort Lauderdale, Florida
    64
    8
    Replacing Trane Adaptive Interface
    I have a new Adaptive Interface Controller that I want to install on an RTAA 080A YT01 air cooled chiller.
    I've read somewhere that all parameters and settings are stored in another module, and changing the interface will be simply plug and play with no actual programming required.
    Can someone whose done this before let me know of any special precautions I need to take?
    I'm planning on auto stopping the system, shutting off power, replacing the adaptive interface and
    turning the powr back on.
    Any advice would be greatly appreciated.
    Apr 2006
    55
    1,908
    30
    Re: Replacing Trane Adaptive Interface
    Best bet is to ask Trane
    manchester
    5,639
    you cant stop a trane!
    Apr 2006
    55
    1,908
    30
    This model has carbon ceramic so all cool
    70
    4,702
    47
    Quote Originally Posted by RackMechanic View Post
    Hi RackMechanic
    I misread your post at first( Think?) If you are talking about a like for like swop, then power off and reboot after fitting the replacement. Cannot do any harm surely?
    If you have purchased or obtained a direct replacement then surely Trane would advise?
    (As chillerman suggests!)
    If you are trying to modify said system, good luck!
    I hope the chiller is sacrificial!
    Apr 2006
    55
    1,908
    30
    Think I misread the post too Grizzly
    Was thinking upgrading not just replacing like for like
    64
    8
    No not modify, like for like. Just hope parameters exist in another module. Time restraints don't allow for full reprogram.
    Aug 2001
    Gold Coast, Australia
    600
    28
    Without the Trane books, you probably can't do a full reprogram anyway, as the manuals provide the settings for all the parameters.
    Is the module a UCM-CLD, or the predecessor?
    64
    8
    Thanks Freezergeezer. It's a UCM-CLD. I did swap yesterday. Easy. No re-programming needed. All info stored in seperate module. Thanks for the help!
