Results 1 to 16 of 16
    Apr 2014
    Mauritania
    35
    11
    Angry Carrier Genesis R 70 trouble (video)
    Best wishes for a happy New Year Brother
    I have a truck Carrier Genesis R 70
    The engine is running a little bit and then stops and issued a strong noise and a lot of black smoke But I note that the clutch works at the beginning ? Is not normal
    There are no alarm in the Control Box !!
    We have examined the battery and all Relay and fusible
    I have checked the compressor and the engine manually, there is no problem everything spins running smoothly
    This video
    Re: Carrier Genesis R 70 trouble (video)
    Looks like belt slip to me.
    Apr 2014
    Mauritania
    35
    11
    Yup Mr Brian
    But in the normal state the engine is running first and then after 7 or 10 seconds and then works to clutch spins the compressor and alternator
    Here are the opposite
    Engine starts overload !!
    Sorry about my bad English
    Feb 2009
    telford
    2,090
    33
    Fuel filter there is one in the pump near tank,one near the engine try starting it on a heat cycle adjust temperature to +20
    Apr 2014
    Mauritania
    35
    11
    Hi #cadwaladr
    I will try him tomorrow
    Thanks brother
    I will tell the results
    Feb 2009
    telford
    2,090
    33
    Ok the engine does not like too much load,but it should start unloaded take care friend
    Apr 2014
    Mauritania
    35
    11
    Quote Originally Posted by cadwaladr View Post
    Hi Mr #cadwaladr
    I change fuel filters
    But still when you started running
    Just the noise and black smoke and then stop !!
    Feb 2009
    telford
    2,090
    33
    Try taking the belt off to compressor and see if it will run be careful only do this for a short time or engine will overheat
    Apr 2014
    Mauritania
    35
    11
    Thenx brother #cadwaladr
    I after remplacing feul filter and clean pump feul filter the ingine want to start normal but now i have Air in feul seystem how I can remove it ?
    Feb 2009
    telford
    2,090
    33
    There is a bleed screw on the injection pump on the side of it think it's a 12mm spanner size,it should bleed itself thru the return line
    Apr 2014
    Mauritania
    35
    11
    Red face Re: Carrier Genesis R 70 trouble (video)
    Thenx To important information
    god Bless you Brother
    Feb 2009
    telford
    2,090
    33
    Glad to help take care because I care.
    Mar 2013
    Wales
    Sounds like the injector pump or injectors mate
    Feb 2009
    telford
    2,090
    33
    I think he has it sorted fixed now?
    Apr 2014
    Mauritania
    35
    11
    Yeh
    #Cadwalar thnx bro
    Evrything work now
    It's done
    Feb 2009
    telford
    2,090
    33
    Great to know,thanks for getting back to us one day I may visit your country and look you up take care.
