Originally Posted by RANGER1 Can anyone explain what this internal check valve is for? Is it when machine turns off it unloads? Does discharge pressure then prevent it unloading. Correct. The Frick hydraulic cylinder is open to discharge on the non hydraulic side. OP < DP running = no relief.
Forum Rules
