    Jun 2014
    uk
    3
    help identifying a cooler ?? Plz
    HI all i wounder if anyone can tell me what is the name of this chiller
    I know it made by Costan but unsure what model
    The reason i'm asking is the unit now has a fault
    its was running perfect so i cleaned the grill at the front & when into the back of the shop to get something to wipe the grill over (a damp cloth)
    while i was in the back....my bright spark of a brother decided to play with the controls (bottom right of the photo)
    Now when the cooler runs its ok for 30 min's the an alarm goes off & flashes HI in the display
    switch the cooler offfor a ,im/ then back on same again ok for 30 min's then the alarm again
    I have phoned a few people to come & have a look at it but they all ask the same question what model ??
    This i'm stuck with......search the internet for 2 days but still nothing
    Could you help Plz Thx phil
    Feb 2009
    telford
    2,090
    33
    Re: help identifying a cooler ?? Plz
    Fit a new controller elliwell id chill or id cool dependent on temp range if the one fitted has one temp probe it's a cool if two chill not worth the time messing then don't take your bro with you again!!!
    Feb 2009
    telford
    2,090
    33
    What you have there is an. Lae controller if you remove it the model number should be on it,he has affected the temperature alarms
    Jun 2014
    uk
    3
    Hi Thank you for the reply
    is there a manual that i can download
    so i can reset the settings myself ??
    Thx phil
    Feb 2009
    telford
    2,090
    33
    Google lae,but you will Need the model number
    Jun 2014
    uk
    3
    Quote Originally Posted by cadwaladr View Post
    Many thx for all your help & pointers
    i found the model number AD2-28 & found the manual in pdf
    If anyone needs it here you go
    file:///C:/Users/dol/Downloads/MULTIDECKAD28_M.pdf
    Again many thx
