Thread: txv and btu's?
    Jun 2007
    saskatchewan
    56
    70
    txv and btu's?
    Are a 1 ton txv for a walk in cooler and a 1 ton txv for a freezer rated the same btu's?If so approximately what btu rating is a 1 ton txv?
    3,853
    Re: txv and btu's?
    I think they are rated at nominal conditions (at least danfoss are) i expect there would be a correction factor for differing conditions. I generally get them sized by the wholesalers technical guy unless it is equipment i am familiar with.
