17-04-2014, 06:32 AM #1
Why do air conditioners blow out white smoke?
I sure that something wrong when I see smoke from my AC. Any one knows that Why do air conditioners blow out white smoke?
17-04-2014, 07:07 AM #2
Re: Why do air conditioners blow out white smoke?
probably condensation after defrost...
17-04-2014, 09:58 AM #3
High humidity and low fan speed. This happens often with Vehicle air-conditioners when the conditions outside are warm but wet and miserable. It's just fog or mist.
Last edited by mikeref; 17-04-2014 at 10:08 AM. Reason: BTW, it only lasts for 15 seconds or so.
17-04-2014, 07:17 PM #4
as mike says running a unit in cooling in low fan speed can create mist- its normal- also recommended to have louvres angled horizontal to prevent dew from forming
18-04-2014, 05:45 AM #5
Thanks all of you for to solve this problem.
01-05-2014, 05:20 PM #6
What kind of white smoke is coming out? Does it have smell? If smells none, probably its a condensation. Be careful also with refrigerant leaks since its very harmful when huffed inside the closed space.
You can also seek professional HVAC adviceLast edited by frank; 01-05-2014 at 06:31 PM.
