    Jul 2008
    Refrigeration based industrial cooling
    This is probably a silly question.
    I currently have a battery of cooling towers, with a cooling capacity of about 4500kW
    Is it totally ridiculous to consider a refrigerant based setup?
    I have looked at adiabatic and air blast coolers, but the foor space they take up is massive, and struggle to achieve the temperature of about 24c during the warmer months
    Thanks in advance
    May 2012
    1,528
    Re: Refrigeration based industrial cooling
    Refrigeration would do that very easily.
    specifics, design, location, application all vary but
    refrigeration was invented to do that very thing
    Remove heat.
    Rob
    Oct 2008
    newbury
    1,444
    air cooled will track DB temp water cooled tracks WB that and the higher efficiency of water means they are hard to beat. the downsides are as you already know.
