Thread: How to calculate enthalpy?
19-10-2005, 11:40 AM #1
How to calculate enthalpy for R22 from the 4 basic equations? i.e.
1.Vapour pressure equation
2. Equation of state
3. Density of the saturated liquid
4. Heat capacity of the vapour
19-10-2005, 04:34 PM #2
Re: How to calculate enthalpy?
The information you are looking for was supplied by the refrigerant manufacturers. Dupont and others used to provide a bulletin that contained the thermodynamic properties and equation of state (EOS) calculations.
The EOS information was in the front of the bulletin.
I have looked on several websites, and it appears the EOS calculations have been omitted from the property information in the current bulletins.
If this is something you really need and cannot find elsewhere I suggest the following:
http://www.nist.gov/srd/nist23.htm
This is a program you can purchase. Contained in the program appendix are the EOS calculations for the different refrigerants.
You can also compile a file from this software code to link to Excel or other programs.
If you have not done this before... Be prepared to spend a lot of time doing so.
Regards,
US Iceman
19-10-2005, 06:12 PM #3
After much searching I found what you are looking for. This is from an old copy I have of R-22 properties. Everything is in Imperial units so you will have to do the conversions into and out of the equations if you are using SI.
Good luck.
Regards,
US Iceman
20-10-2005, 05:26 AM #4
Thanks Iceman. But how to calculate Enthalpy value from the equations?
20-10-2005, 06:56 AM #5
Hi Thing,
ehthalpy=Cp*T,iceman offered equation can get Cv,so that you can get enthalpy by h=CvT+pv. Details you can refer to ASRHRE handbook fundamentals. If need ,pls give me your email.
rgds
LC
29-10-2005, 03:10 PM #6
Mate I'd be getting my hands on the molier chart and plotting it. The equations will only make sense when you can see the refrigeration system right in front of you.
Thats my 2 cents
Howto: Calculate coaxial heat exchangers
By JKProSoft in forum Technical SpeculationsReplies: 14Last Post: 10-01-2011, 12:10 PM -
Subcooled Enthalpy Values?
By Calvin Becker in forum Technical SpeculationsReplies: 4Last Post: 08-01-2006, 04:44 PM -
Help to calculate Heat Exchancger
By Carode in forum FundamentalsReplies: 1Last Post: 17-12-2003, 10:57 PM -
Calculate cap tube
By herefishy in forum Technical DiscussionsReplies: 55Last Post: 04-11-2003, 08:31 PM -
How do you calculate Superheat?
By zolar1 in forum TrainingReplies: 39Last Post: 10-05-2002, 02:37 AM
