    patriot_p's Avatar
    patriot_p Guest
    Can someone help for Soft Starter Termination
    Can someone help me to install this soft starter i didn't understand the wiring diagram so please check the attached image and rep me.
    Re: Can someone help for Soft Starter Termination
    That wiring diagram and instructions seem plain enough, what exactly is your problem with the wiring?
    patriot_p's Avatar
    patriot_p Guest
    actually i want to know the control wiring in simple words like 220 volt on flt or st or whatever.
    May 2010
    Russia
    168
    Functional diagram from 3 page of your booklet.
    L1,L2,L3 it is LINE.
    U, V, W it is MOTOR
    Start/Stop it is operation signal (input)
    FLT it is alarm relay (output).
    In real diagram you need magnetic contactor with thermal overload relay.
