Results 1 to 15 of 15
    Mar 2006
    Lancashire
    1,859
    28
    Electrical test leads
    Gents,
    I'm looking for some small tip electrical test probes, to be able to test hard to access terminals.
    I have a fluke 116 multimeter and the tips of the test leads are quite small but after trying to take the resistance readings on a CN plug for a Daikin condenser fan motor today I found they aren't small enough.
    I ended up using a paperclip to push into the CN plug to take the readings but was hoping to be able to get a set of smaller tip test probes to use with my multimeter.
    The only ones I've seen are the FLUKE TL910 but they are pretty pricey at £60
    Which ones do you use?
    Marc
    manchester
    5,639
    Re: Electrical test leads
    get 15amp fuse wire- wrap it around your prongs- and secure with insulation tape
    3,853
    Got a set like this,
    http://www.amazon.co.uk/Fluke-Tlk287...uke+test+leads
    Cost more than the tester!
    Feb 2007
    2,473
    Go to your local MAPLIN and have a look they got plenty to choose from.
    Mar 2006
    Lancashire
    1,859
    28
    Thanks but I'd prefer a proper set of test leads, good idea though.
    Marc
    Mar 2006
    Lancashire
    1,859
    28
    Hi Viking,
    I bought my last set of test leads from there but they didn't have the small tip probes at the last store I tried.
    Someone recommended RS but their website has been down for most of the day.
    Marc
    Split Croatia
    6,151
    Mar 2006
    Lancashire
    1,859
    28
    Now that is a set of test leads!! Definatly food for thought!!
    Marc
    Feb 2007
    2,473
    Or something like THESE for £4.29...
    manchester
    5,639
    too cheap for mark them viking-
    Mar 2006
    Lancashire
    1,859
    28
    Haha, they look good but it doesn't show the width of the tips.
    The fluke ones are 1mm but are £55...... I'm not as well off as you IM
    Marc
    3,853
    Have a look on ebay,
    http://www.ebay.co.uk/itm/1-Pair-20A...item43c1fcdf2b
    not sure if these any good but expect there would be something there.
    Apr 2008
    Southampton, England
    49
    1,023
    Forget all the fancy connectors. Strip connector (choc box), one end on the probe and either a pin or paper clip in the other. Not had it fail me yet and I can abuse and lose them and not lose any sleep.
    If the boss is paying, well different story
    Cheers, Andy.
    Mar 2006
    Lancashire
    1,859
    28
    They look small enough, I've ordered a set of them. If they don't work I'll go with the fluke.
    Thanks MS, much appreciated
    Marc
    Mar 2006
    Lancashire
    1,859
    28
    Another good idea that Andy.
    If the ones I've ordered ever break I'll remember that.
    Marc
