Results 1 to 10 of 10
    Dec 2010
    ireland
    Dixell controller help
    I am working on a Linde multinor 1540/80 dual temp cabinet with a dixell controller and the cabinet keeps icing up once a month and I can't check defrost settings.
    i changed the defrost probe and heaters are working but will only stay on defrost for 5min.
    hopefully someone might info on these
    manchester
    5,639
    Dec 2010
    ireland
    Re: Dixell controller help
    Thanks install monkey but my controller looks different and tried all the regular controllers parameters but just can't get in to parameters. Mine is a display linked to a small pcb board
    manchester
    5,639
    Try emerson.climate europes website then as they do dixell-
    ireland
    1,453
    what model is it padraic? usually hold up (or down arrow, can never remember which) and set, displays first parameter, release and press and hold again, after a few seconds gives you all parameters.
    manchester
    5,639
    Dec 2010
    ireland
    That looks like it allright but it just won't let me in no matter what I try.. CON will display and nothing else...?
    Dec 2013
    GB
    48
    8
    Put an elliwell on it.
    manchester
    5,639
    level 2 password 321
    Jan 2008
    north west
    42
    234
    Should be set and down for 5/6 seconds then show pas enter 3 2 1 as pass code and your parameters will be accessible.
    The last thing to leave an engineer is pride!!
