    May 2013
    Indonesia
    38
    2
    small size Organic Rankine Cycle (<10KW) design
    I wonder if anyone have try to design small ORC with turbine capacity less than 10KW with R134-A?
    I try to design one but wonder what is the optimum operation pressure for the turbine.
    If we use air cooler as condenser so the temperature & pressure of the refrigerant have some limitation to prevent cavitation in the pump
    Thank you.
    manchester
    5,639
    Re: small size Organic Rankine Cycle (<10KW) design
    May 2013
    Indonesia
    38
    2
    Thx.. anway, the design of the machine usually not being utilized in an area which have high ambient temperature >30C which make the condensing method & efficiency poor.
Tags for this Thread
