Results 1 to 50 of 226
27-03-2013, 06:02 PM #1
Re: k20 Ignis Blizzard icemaker issue with not starting
To test before installing the only way is to continuity test across the terminals. Check the wiring diagram to find the normally open contact and test across and then click the stat to the harvest setting and test again. Personally if its in operation and on harvest setting and doesn't kick into harvest I would replace the stat again.
06-04-2013, 09:40 PM #2
tip, make sure ur drain from the bin has a good fall, as when it goes on harvest mode, it fills the trough and excess water will drain, your 1st batch of ice will defrost before the next batch drops, keep the door shut,and lets hope ur bin stat cuts out when ice fills the bin!- im impressed with your perseverance
