    Mar 2013
    United States
    1
    Walk in freezer 404a -12 degree box temp drain line freezing and pan??
    I shut down box to defrost and cleared condensate line and is insulated but keeps freezing what next?
    3,853
    Re: Walk in freezer 404a -12 degree box temp drain line freezing and pan??
    Is the drain line heater working and /or drain clear of blockages? If not water will back up into the drain pan. Is the fall correct on the drain line?
    Jan 2009
    58
    161
    Is there a trap fitted? If not warm air will freeze inside the pipe!
    Sep 2011
    84
    14
    Try some self regulating heat tape like you would use on gutters for a house to keep them from freezing.
