23-03-2013, 11:30 PM #1
Re: Daikin Altherma HT(16kw) eroor code JA16( Malfunction of high pressure sensor)
By resetting the power you will only temporarily clear the fault until system comes back on and it senses once again a faulty high pressure sensor, hence why it cuts off after a few minutes as you have described. My advice is either : getting the installers to have a look at it as its only been installed a year or so, test the transducer as i previously said OR get a specialist to come and diagnose the problem. If its a problem with the refrigerant gas side of system then you will need to be F-Gas registered to work on it.
