    Apr 2012
    Iraq
    624
    minimum distance between wall mounted split and ceiling ????????????????
    hi
    when install split unit
    what is minimum distance should i consider between the upper end of wall mounted split unit and ceiling
    as u know the hot air and smells and vapors are collecting there
    manchester
    5,639
    Re: minimum distance between wall mounted split and ceiling ????????????????
    typically over 50mm to allow for removal of the facia, but a lot of wall mount evap coils are in an A shape so it makes it difficult to spray the coils on maintenance visits
    Aug 2004
    744
    Sorry OT...
    Do you work for yourself Monkey or are you employed?
    manchester
    5,639
    employed if i was self employed they id go bump in a week for being too cheap!
    Quote Originally Posted by eggs View Post
    Sorry OT...
    Aug 2004
    744
    ok, just remember there are options........we should talk.....
    eggs
    Apr 2012
    Iraq
    624
    the minimmmum distance that i found is 20 cm
    thank for help
    please close the thread
    May 2011
    India
    38
    106
    14
    A max distance of 2-2.5meters can be considered. Also, its recommended to keep the outdoor (condensing) unit below the datam line of evapoarter, as in the other case, where the condensor is located in a higher position than evaporater, the compressor have a hard time suckin the oil back to it... No proper oil return will cause compressor failure!
    If the condensing unit is below, the oil comes back to the compressor automatically (gravity).
    Apr 2012
    Iraq
    624
    thank for help
