Thread: CDK Coldroom Controller
Threaded View
30-01-2013, 09:16 PM #2
Re: CDK Coldroom Controller
You need a CDK handset and you also need to set the bit switches on the card for the particular application. E.g HT or LT/ cold room or case and defrost control. If the system is networked to a CDK storescan/ miniscan you can access the settings through those. If you pm me i will send you the bit sw config for your application which will put default settings in, but you will still need a handset for inputting user defined settings.Last edited by RONB; 30-01-2013 at 09:18 PM. Reason: Spelling
