Thread: Power factor?
20-01-2013, 10:23 AM #1
Power factor?
In one sentence can someone explain power factor with reference to reactive, real and apparent power? Or maybe two sentences
The more I learn the less I know......
20-01-2013, 10:30 AM #2
Re: Power factor?
Last edited by install monkey; 20-01-2013 at 10:31 AM. Reason: brian taught me well!! haha
20-01-2013, 05:09 PM #3
Re: Power factor?
with high power factor current/voltage waveforms are syncronised
with low power factor they are not and cause higher amp draw
R's chillermanIf the World did not Suck, We would all fall off !
20-01-2013, 05:30 PM #4
Re: Power factor?
20-01-2013, 06:47 PM #5
Re: Power factor?
fit more save the planet!
21-01-2013, 12:32 PM #6
Re: Power factor?
P = ROOT 3 * V * I * PF (COS #)... #= Angle between Current and Voltage. Current can either lead or lack voltage vice versa.Both lagging and lacking are not desirable and this angle should be minimum.Optimum power factor is one that is angle between current and voltage is zero, so cos 0 = 1.
The advantages of optimum power factor is already explained by Chillerman i.e les amperes drawn, better efficiency..
