    Jun 2007
    yorkshire
    71
    13
    hotpoint ff187e fridge freezer
    freezer coil iced up defrosted coil, is thare away of forceing defrost on to check heaters.
    what ohms reading will sensors be
    manchester
    5,639
    Re: hotpoint ff187e fridge freezer
    would have thought the resistance of a heater would be around 27 ohms- anything above zero ohms, test continuity between ends, also check the termination stat which will stop the heater from running once the ice has cleared. ohms law will give you the wattage- resistance over 240v unless the voltage differs on the wrong side of the pennines
    Last edited by install monkey; 01-01-2013 at 04:46 PM. Reason: watch the domestic guru's jump all over my 27ohm comment! haha
    Jul 2006
    norfolk
    737
    Evaporator Defrost Heater:
    387.2 Ω
    Gutter Heater:
    1.61 KΩ
    all info on our website
    check out my website www.airkooldomestics.co.uk
    Jun 2007
    yorkshire
    71
    13
    heaters test out ok ,but still need to know sensor resistance
    is it possible to force controle into defrost
    Jul 2006
    norfolk
    737
    SENSOR RESISTANCE TABLE (
    Ω)
    Temperature (
    °C) Resistance (kΩ)
    -30 175
    -25 129.2
    -20 96.3
    -15 72.5
    -10 55
    -5 42.1
    0 32.5
    5 25.3
    10 19.8
    15 15.6
    20 12.4
    25 10
    30 8
    35 6.5
    40 5.3
    45 4.3
    50 3.6
    55 2.9
    60 2.4
    65 2
    Jun 2007
    yorkshire
    71
    13
    sensor test out ok maybe time to go comit and buy new fridge on a fridge engineers wage
    manchester
    5,639
    http://www.currys.co.uk/gbuk/aeg-s95...97900-pdt.html found you 1, will keep your beers chilly
    Quote Originally Posted by roger the chill View Post
    Jul 2006
    norfolk
    737
    before you bin it email us and i send you tech for it airkool@hotmail.co.uk
    Jun 2007
    yorkshire
    71
    13
    thanks tonto33 looked at your website and found some info .
    just donot have time proper job has gone crazey .
    never had problems like this with fridgeadair meter mizers
