    solankisagar's Avatar
    solankisagar Guest
    How much gas will be required......pleaseeee help
    I am making deepfreezer need some help.
    using
    evaporator, pipe 3/8 around 50 feet
    compressor 1/2 hp
    how to calculate (or any software to calculate)how much gas will be required for this machine while charging.
    R134a
    May 2012
    1,528
    Re: How much gas will be required......pleaseeee help
    134a
    .............................Liquid... Hot Gas
    ...............................Line.....Line (55°C)
    .......................................................................-40°C.......-30°C......... -20°C.......-10°C...........0°C
    Inches....................kg/m........gm/m...................gm/m.......gm/m.........gm/m.........gm/m........gm/m
    3/8.......................0.0595.......2.2322.................0.1488.....0.1488........0.2976........0 .5953.......0.8929
    I have it all in table form if you send me your email I will forward a copy to you (the formatting is all over the place but the original table is easy to use).
    134a 3/8 pipe in liquid is 0.0595 kg/m
    134a 3/8 pipe suction at -10 is 0.5953 gm/m
    Rob
    Oct 2003
    5,630
    Quote Originally Posted by solankisagar View Post
    using
    compressor 1/2 hp
    R134a
    Just till your SH reaches the desired value of +/- 6 to 5K. As easy as that.
    Nov 2006
    Middle East (United Arab Emirates)
    43
    Dear Rob White,
    May I request you to send me too a copy of the table. My e-mail ID is rayin123@gmail.com
    With thanks and regards
    Rayin
