    Aug 2012
    France
    56
    9
    Condensing Unit Hermetic Compressor - Stalling and Tripping??
    Hi Everyone,
    Just looking at an Ice Cream Van with a small 1ph hermetic condensing unit (on R409A).
    The customer tells me a capacitor exploded and he replaced it, but fridge not cold.
    When I turn the unit on it starts ok and works for maybe a minute. Back Pressure falls Head pressure rises, all looks great, but then the compressor starts 'rumbling, and stalling' and after 10 - 15 secs, trips on the internal thermal overload.
    The capacitor looks fine, is the same rating 80mf. The relay is wired correctly. But the compressor is too hot for the work done when it cuts out. I've tested the windings (cold) ad they check out more or less ok, they pretty much add up.
    Any ideas???
    Cheers guys.
    FrenchFox.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Condensing Unit Hermetic Compressor - Stalling and Tripping??
    That's a good sign that you have a restriction somewhere in the unit. Have a good check up to find it.
    38
    Check motor current, to make sure the relay is dropping out start winding after startup.
    Aug 2012
    France
    56
    9
    Good advice thanks.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    80 uf is the start capacitor. There is a run capacitor to check as well.
    manchester
    5,639
    condenser coil, clean? fan working- wont be a weak klaxon, clip the running current, pot may be siezing
