    May 2012
    uk
    2
    polar t316 ice machine problem
    I have a polar t316 ice machine with a fault, on turning on it goes through the cycle of the tray dropping and then raising then fills with water but as soon as full drops again and water still continues to pour in, refrigerant works and then heats up but the tray will not rise to allow water to freeze.
    hope someone can help
    thx
    manchester
    5,639
    Re: polar t316 ice machine problem
    check ur e mail- sent you a manual-possibly water valve passing(solenoid or float)
    May 2012
    uk
    2
    ok thx for that, anyone had similar problem?
    Dec 2006
    105
    Hi. We have had similar problems in the past. On the tray that fills up with water, there is a persistent problem with the nut (that connects the tray to the motor) that gets loose, and because of this when it fills up with water the bin can't take the weight and the bin drops. Just tighten this nut and all should be fine. If this doesn't help, just says so, and we can go a bit further.
    Oct 2012
    Carlisle
    43
    1
    Quote Originally Posted by stevem0030 View Post
    Have a similar problem at the minute. Tray goes up, starts to fill then the fault light comes on. Any chance someone could send me the manual?. Thanks.
