Page 1 of 3 123 LastLast
Results 1 to 50 of 108
    Apr 2006
    55
    1,908
    30
    Chiller Passwords / Codes
    The attachment is a collection of 'Chiller Passwords'
    R's chillerman
    Dec 2008
    563
    Re: Chiller Passwords / Codes
    Most helpful, thank you.
    Jun 2011
    Australia
    44
    336
    22
    Good document, thank you.
    Apr 2006
    55
    1,908
    30
    Can anyone assist, with updating the list of passwords further ???
    Jun 2011
    Australia
    44
    336
    22
    Here's one not on the list, Unisab II - 1266, 8270
    Apr 2006
    55
    1,908
    30
    Quote Originally Posted by HVACRsaurus View Post
    Nice one HVACRsaurus
    will add that straight thankyou
    R's chillerman
    manchester
    5,639
    are u expanding this list to involve ac units?
    Apr 2006
    55
    1,908
    30
    Oh yes mate, Good Idea ........ if we can start to add a/c codes aswell - it all helps other members
    manchester
    5,639
    lennox flexi unit-using kp02 controller access code 63 to adjust parameters.after 10 mins will req inputting again
    ireland
    1,452
    Edpac close control units, 1234 or 4321 to access programming, applies to older model carel pico controllers.
    manchester
    5,639
    liebert ics controllers
    At the unit, the first step is to access SET MODE 2. This adds a second level of functions to the
    LED indicators on the microprocessor board (below the numeric display).
    To access SET MODE 2:
    1. Use the ADVANCE button to select TEMPERATURE.
    2. Simultaneously press and hold the up and down buttons for 5 seconds. The TEMPERATURE
    LED will blink, indicating SET MODE 2 functions. Release the up and down buttons.
    To set Temperature and Humidity alarms:
    1. Use the ADVANCE button to select the desired function.
    2. Use the up and the down button to increase or decrease the value shown on the numeric
    display.
    To return to Normal Set Mode:
    The microprocessor automatically returns to Normal Set Mode 30 seconds after last activity.
    3.4.3 Alarm Indications
    Change Filters
    The filter change switch senses a pressure drop across the air filters and activates the Change Filter
    and audible alarm when the pressure drop reaches a customer preset level. Instructions for
    adjusting the switch are on a label near the switch.
    Loss of Air Flow
    On ICS units, the fan safety switch is located on the low voltage panel and consists of a diaphragm
    switch and interconnecting tubing to the blower scroll. The normally open contacts of the
    switch will close at a factory preset air velocity and energize the control voltage circuits (see schematic
    on unit). Upon loss of airflow, the normally closed contacts on the switch will activate the
    Loss of Air Flow and audible alarms.
    High Head Pressure - Compressor 1 (& 2)
    The high head pressure cut-out switch activates the HIGH HEAD PRESSURE LED and the audible
    alarm at the cut-out setting of the compressor pressure switches.
    Water Under Floor
    The Liqui-tect
    ® Water Detection Sensor (optional) consists of a solid-state switch that closes when
    water (or other conductive liquid) is detected by two sensor probes. The sensor may be mounted
    Table 2 Temperature and Humidity Settings
    Normal
    Functions
    Set Mode 2
    Functions
    Temperature Temperature Sensor Calibration ±5°C
    Temperature Set Point High Temperature Alarm (from 1° above
    setpoint to maximum of 90°F/32°C)
    Temperature Sensitivity Low Temperature Alarm (from 1° below
    setpoint to minimum of 35°F/2°C)
    Humidity Humidity Sensor Calibration ±5% RH
    Humidity Setpoint High Humidity Alarm (from 1% above
    setpoint to a maximum of 85%)
    Humidity Sensitivity Low Humidity Alarm (from 1% below
    setpoint to a minimum of 15%)
    Humidifier Water Rate Lead Compressor 1 or 2
    manchester
    5,639
    daikin chillerEWAQ080~260DAYN
    1234
    Apr 2006
    55
    1,908
    30
    Thanks Gents
    I will add a close control section to doc, as it fits, just codes
    But think it maybe an idea to start a thread for the more involved a/c procedures
    Will cut/paste these to new thread, once me little puppies have stretched their lttle leggies
    And scared off the rif raf in the park
    R's chillerman
    Oct 2004
    U.K.-London
    144
    Denco With PCO carel control
    Key for this forum:
    up arrow =u
    Down arrow=d
    Right arrow= enter =e
    Level 1: udududu e
    Level2: uudduud e
    Level 3: uuuddduu e
    Level 3- factory- uuu e
    Carier pro dialog pus
    User password 11
    Service password 88
    Trane - not sure which chillers they apply to anymore
    314
    159
    Dunham and bush: carel control
    Maintenance 1234
    Program 4321
    Factory 4321
    Acres factory menu by pushing menu and program simultaneously
    Never underestimate anybody, you never know when they will make you look like an idiot!
    Oct 2004
    U.K.-London
    144
    Stulz: not applicable to all:
    Control: left arrow; menu; right arrow
    Service: right arrow; menu; left arrow
    The trick is to input the code when the blinking ":" on the clock is on, otherwise it'll reject you
    The above passwords could be the other way around; ie the service password could be the control password and vice versa. I'm not in front of the machine
    Sep 2006
    italy
    93
    Thank you guys,
    very usefull for everybody
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    very helpful,thanks.
    moideen-dubai
    Jan 2011
    sydney
    Top thread guys, Here's my list
    Mcquay with pco 2: Italian chillers
    maintenance- red, print, blue
    factory settings- (hold prog and user) blue, print,down
    exv- (found in factory settings) 13
    service- (hold prog and spanner) up, down, print
    Mcquay PFS (china)
    sign in - ADMIN
    passwd- 80191023
    Mcquay pcob
    1702
    Mcquay microtech 2
    user- 2001
    tech 13317211
    Turbocor compresser
    62876
    MTA
    1234
    3204
    Powerpax chiller
    old- last 3 digits of serial #
    new- add two middle digits of of serial # to make a 3 digit #
    Jun 2006
    42
    McQuay chillers again,
    1) - 0033
    2) - 0018
    3) - 0003
    4) - 1702 - locks circuit out
    Mar 2012
    italy
    67
    77
    13
    Clivet 321
    softair_hvac's Avatar
    softair_hvac Guest
    Thumbs up Re: Chiller Passwords / Codes
    Quote Originally Posted by chillerman2006 View Post
    R's chillerman
    Good work ( chillerman )
    Many thax
    Jakub's Avatar
    Jakub Guest
    if anyone knows the password (code) for compressors grams grammatic2502 driver?
  23. #23
    Feb 2009
    telford
    2,090
    33
    does anyone know anything about a controller made by MERCURY or is it a model name,i was helping a friend today on a cold store system which had two of these fitted and all it would show was PD? and i did not get to see a type/model number any help appreciated.
  24. #24
    Jul 2007
    Spain
    40
    7
    Daikin EUWA***HDZ
    EUWA***KZW1
    EUWAC****FZW1
    EUWY*****KZW1
    Password:
    1234 user
    177 Manager
    2001 manager
    1914 > manager
    thx to share
  25. #25
    Jun 2008
    H.K.
    5
  26. #26
    Apr 2012
    Bergen
    3
    RC (RCgroup) - 5625
  27. #27
    Jul 2012
    38
    1
    R's chillerman
    Thank You, this was a life saver
    -PK-
  28. #28
    Mar 2010
    usa
    120
    Thank You...This will save lot of time.
  29. #29
    Darkling's Avatar
    Darkling Guest
    Stalectronic S700
    Level 1: 16134
    Level 2: 14848
  30. #30
    Oct 2010
    Scotland Inverness
    11
    Carrier 30HX
    Code 11 and 88
  31. #31
    May 2011
    EGYPT
    11
  32. #32
    Aug 2009
    Torokszentmiklos
    thanks. it is good!
  33. #33
    Oct 2012
    Usa
    2
    Hey guys,
    Have a carel pco1 on a 280' Motoryacht. Have tried all the codes from chiller man and the ones on this forum. The engineers aboard don't have them either.
    Any Ideas? Really just want to clear hours on units after servicing to get alarms off screen.
  34. #34
    Jun 2009
    Lusk , Dublin
    1,115
    Carel default passwords are 1234 / 4321 . but it is sold unprogrammed to many manufacturers so they can configure it themselves . Try 6666 / 7777
    cheers
    Stu
  35. #35
    Oct 2012
    Usa
    2
    Thanks for the tip, but no joy...
    Is there a way to reset the password?
    Problem is with these ships is not a lot of documentation and when the original engineer goes a lot of valuable information goes with him...
  36. #36
    Jun 2009
    Lusk , Dublin
    1,115
    Not that i know of, last try 0011 / 0033 / 0066. After that dont knowGood luck
    Stu
  37. #37
    Oct 2012
    Russia
    42
    392
    De Longhi Professional AC
    User 1234
    Admin - 9990
  38. #38
    Nov 2012
    1
    Quote Originally Posted by Jakub View Post
    grammatic 2502 password 1.5 found this on two gsv111
    unisab 3 1357 default
  39. #39
    Jun 2012
    Germany
    4
    Mc Quay Microtech 3 Controller (Siemens)
    User 5321
    Manager 2526
    Service 6363
  40. #40
    Dec 2009
    Germany
    1
    You are great, all of you!
    Thank you
    Coolfritz
  41. #41
    Aug 2010
    110
    14
    Does anyone perhaps have a password for the York YCIV so that I can change the serial number. We had to change out the microboard and had one in stock but now we need to program the serial number. The manual says these are only available from York but time does not permit.
  42. #42
    Jun 2011
    Australia
    44
    336
    22
    Hi Piewie, 2878 as given to me by Chillerman - but unconfirmed by myself..
  43. #43
    Mar 2013
    Ukraine
    1
    Multiscroll Chillers DAIKIN EWAQ... series . SERVICE PASSWORD 1914 . Confirmed.
  44. #44
    Apr 2013
    italia
    1
    thanks to all, you are strong
  45. #45
    Aug 2007
    Sydney
    52
    1,083
    Powerpax chiller
    just open an Excel Spread sheet and paste the =(IF((C3+D3)>9,1,0)+B3) & (RIGHT(C3+D3,1)) & E3 formula in. Looks like this
  46. #46
    Feb 2006
    Liverpool
    Looking for the access codes for a YORK YCCD 20 ??
  47. #47
    mech's Avatar
    mech Guest
    Many thanks
  48. #48
    Apr 2010
    Qatar
    43
    28
    Good ...............................................................
  49. #49
    Feb 2008
    Pakistan
    Dear i am needed the Microtech-III controller software, its loaded by SD card and chiller detailes are as below.
    McQuay Italy
    Air cooled single screw
    Model: MNG 100208 MNO
    Could you please help me in this regard.
  50. #50
    Feb 2008
    Pakistan
    McQuay Italy
