    Aug 2012
    new zealand
    33
    4
    Smile heating problem with lg unit
    hi there
    I am having trouble diagnosing a problem on a split lg this is the firs lg i jave worked on so have no information on these whatsoever.
    The unit works fine on cooling mode every thing as it should however once changed to heating the (what appears to be)defrost symbol on the air handler display shows up instantly have tried the basic reset and still nothing the air handler fan runs intermittently however the outdoor unit will not run no compressor no fan and the reversing valve engages unit is not s.o.r and have a healthy 230-supply have a gut feeling that it maybe a sensor? or a board? If someone has the resistance.values for the sensor this would be a great help
    Apr 2007
    371
    Re: heating problem with lg unit
    Thermistor....pretty sure we had this before, ring Lg technical they love all that resistance nonsense. Can get they're number if you ring Dean and wood.
    Best of luck
    Dec 2005
    Cheshire
    264
    What is your outdoor temperature??
    Many splits will not work on heat mode above 20degC ambient.
    Oct 2008
    newbury
    1,444
    Quote Originally Posted by jdunc2301 View Post
    Best of luck
    ring D&W from NZ
    manchester
    5,639
    manchester
    5,639
    2 posts and 2 recommendations for secure comfort- they must be good!!
    3,853
    Quote Originally Posted by makrin View Post
    Hey, my friend also faced a similar problem with air conditioner and he got it serviced by securecomfort at an very reasonable price
    ...and of course you have nothing to do with them despite you email address being at that company....
Tags for this Thread
