Thread: Carrier 30rb-017 chiller
31-07-2012, 02:06 PM #1
Hi all, im a first time poster so not too sure if im in the right section here.
We've just installed 2 carrier aquasnap 30rb-017 air cooled water chillers feeding 6 fan coil units. When it came to commissioning, with the user code in the manual you cant even get access to set the time and date on the controller, its a pro dialog +. There is not a chance we are going to pay for a carrier engineer to come out just to commission this equipment when we can do it ourselves. So does anybody know the engineer codes to access the further menus.
Cheers in advance Craig
31-07-2012, 06:36 PM #2
Re: Carrier 30rb-017 chiller
Hi mate,
Search in the forum thread with the title heading 'Chiller Passcode'', maybe there you'll be able to get some help. Good luck
31-07-2012, 08:23 PM #3
Craig,
Silly question but...
What warranty does Carrier offer if it isn't one of their guys commissioning it?
31-07-2012, 09:01 PM #4
as said try searching but ill save you some time
beware user pass is 11
and service is 88
beware not to change anything critical or you will need carrier !!
good luckTHE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
31-07-2012, 10:26 PM #5
I'm with the Viking, unless I am out of touch?
Carrier have to commission their chillers to validate the warranty!
So if you have issues "don't hold your breath" on the necessary back-up.
31-07-2012, 10:59 PM #6
31-07-2012, 11:28 PM #7
Cspeed
The access code is given in the manual, "11", you not need any other code unless you are running brine/glycol. I've been having trouble with one as well, the code was changed, but we worked it out!!
Check with Carrier re your warranty, might be worth paying a day for them to come if it increases your warranty but check that the extended warranty doesn't depend on carrier visiting for maintenance....
alMostly found in the southern part of this green and pleasant land.
