Results 1 to 50 of 226
11-07-2012, 04:13 PM #1
Re: k20 Ignis Blizzard icemaker issue with not starting still
Originally Posted by B G Scott View Post
Once again have you checked that the BIN thermostat is closed, if you look at the back of the machine you will see a knob with a sun and a snow flake on it, this is the bin stat.
Just to test if it is OK or not, remove the wires and temporarily join them together and then see if the pump and compressor starts.
I needed to take a look at the BIN thermostat according to BG Scott. And I also did the Ice thickness thermostat.
I joined both, the result is still the same. Not working not starting the compressor.
And the videos are here are the results:
ice maker ignis blizzard k20 ice thickness thermostat joined together:
http://www.youtube.com/watch?v=bYMYVqxU6Ko
icemaker ignis blizzard k20 Bin thermostat joined on:
http://www.youtube.com/watch?v=gAKw-a7QAf8
29-07-2012, 07:35 AM #2
And if that transformer is busted it is expensive to replace!
I will think. I need to check other things too but nobody here can help me to make a step by step troubleshooting?|
