    rajuafs's Avatar
    rajuafs Guest
    Identifying R404A
    Gents,
    How can anyone identify whether the refrigerant supplier has supplied genuine refrigerant
    R404a?
    Please help me.
    May 2012
    1,528
    Re: Identifying R404A
    Use the pressure temperature relationship test.
    At any given temperature the refrigerant will be at a certain pressure.
    Measure the temperature of the cylinder, measure the pressure of the
    cylinder and they should corrispond with what it should be on a chart
    or comparitor.
    Rob
    Feb 2009
    telford
    2,090
    33
    thats the only way i know,why do you ask the question if you doubt your supplier find another not worth the risk!!
    manchester
    5,639
    May 2012
    iraq
    65
    11
    normaly for cooling down to 0C. the suction pr = 50, discharge pr = 300 psi.
    and these nos. could be slightly diff due to weather and charge.
