Thread: Vacuum pump oil
    Nov 2007
    Australia
    64
    Vacuum pump oil
    Hi Guys..
    I'm in the middle of Indonesia at the moment and have run out of vacc pump ..
    Would anyone out there know if there is a substitute oil I could use in a 2 stage vacc pump.?
    Peter
    Jun 2011
    Australia
    44
    336
    22
    Re: Vacuum pump oil
    I reckon whatever refrigerant clean / new refrigerant oil you have would be fine. Pretty sure most vac oil is just some middle of the road mineral oil. Else, engine oil would probably do just fine.
    Nov 2007
    Australia
    64
    Re: Vacuum pump oil
    Thanks for your feed back mate..
    Jun 2009
    North East England
    712
    Re: Vacuum pump oil
    I often use compressor oil when vaccing down bigger machines then swapping to vac oil when I'm near torr
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Vacuum pump oil
    Yeah POE, PAG or PVE oil is just as fine.
