    Feb 2008
    502
    pressure switches
    worked on a freezer unit to day the hp switch was conected to the compressor oil pump and the oil switch was conected to the hp conection of the compressor head. i had to look twice never seen pressure switches piped like this befor
    manchester
    5,639
    Re: pressure switches
    swap the cables over-oops jumped in a bit too quick there- degas and swap the capillarys over
    Feb 2008
    502
    the only parts corect was the wires and the lp conection on the oil switch
    Oct 2008
    newbury
    1,444
    OOOOO you beat me to it !
    manchester
    5,639
    posted swap the cables then edited it as i thought theyve probably got the pressure switches in the wrong ports-so edited it quick! haha
    May 2012
    59
    1,528
    Was it done by accident?
    Or was it done because the oil pressure is so low they
    piped the HP to to oil switch to keep it running?
    If it is the latter you may find the comp is in need of attention.
    Rob
    Feb 2008
    502
    its on a rebuild after the first rebuild failed so might just be a mistake or some one not knowing wot thay were doin but not a good mistake to make
    manchester
    5,639
    at least you get 90seconds of head pressure delay ! haha
    Aug 2008
    55
    259
    I think we've all done similar stuff like this. I know, on the odd occasion, I've wired stuff up and checked it then about to turn it on and do a final check and find I've wired the earth too the live or something stupid like that. Its like you put a tool down, go looking for it and it seems to have disappered then look again and there it is. Sometimes strange how the mind works...or more to the point how it doesn't work sometimes!
