Results 1 to 34 of 34
Threaded View
19-06-2012, 05:10 PM #11
Re: Compressor unit broke- only 1yr old!
HRP must be sending out dodgy makes then in 7 years i've had only 1 duff compressor.... haha
Brilliant advice, rep points on the way....
If the installer has installed the unit in a crap location or not carried out his works properly the blame could lie with him, on the other hand if the unit is choked up with dust and grime and hasn't been serviced...then its your fault for being tight .... just saying as you didn't answer if it had been serviced or not...
Are your contractors offering up reasons as to why the compressor has failed, often you cannot fully interogate and fault find until the new compressor is fitted, however he should be able to offer up some explanation to you as to why it has failed...Also don't always go with the cheapest quotation, compare them closely, as the first firm may have decided to change electrical components (contactor, capacitor etc) and protection devices like High pressure switch etc to cover all the bases and make a lasting repair.....
J
