Results 1 to 50 of 226
Threaded View
18-06-2012, 11:34 PM #9
Re: k20 Ignis Blizzard icemaker issue with not starting
B G Scott:
Ok so for now do you think it is worth testing without the ice thickness thermostat?
I can manage to test if you show me how to hook up the cables. Or link the cables.
I can say for now. The greenbutton pressed in never gave me a starting compressor.
Only when I connect the compressor cables directly to the 220V(black cable and the other brown cable) it will start. Which means the compressor is doing fine.
What else can I try?
