Thread: starnge device
24-05-2012, 08:47 PM #1
starnge device
hi every one
i have question
i saw a device in 2 ton window type air conditioner
the device is contain electric coil similar to reverse valve coil
and its connected to the compressor discharge pipe from one side and by 2 capillary tube to the entrance of evaporator
what its
these are photo for it
Power consists not in being able to strike another but in being able to control oneself when anger arises
24-05-2012, 08:50 PM #2
Re: starnge device
liq injection solonoid-in heating mode the outdoor cool can freeze up in low ambient- this squirts gas to raise the coil temp
24-05-2012, 08:56 PM #3
Re: starnge device
thank you
can you explain morePower consists not in being able to strike another but in being able to control oneself when anger arises
24-05-2012, 09:20 PM #4
Re: starnge device
https://rapidshare.com/files/4137667...ual_Part-1.pdf;
https://rapidshare.com/files/3320555...ual_Part-4.pdf;
https://rapidshare.com/files/2245014...ual_Part-3.pdf;
https://rapidshare.com/files/2244454...ual_Part-2.pdf;
https://rapidshare.com/files/2149991...ual_Part-6.pdf;
https://rapidshare.com/files/1140769...ual_Part-5.pdf;
this might help-your english is better than mine!
24-05-2012, 09:31 PM #5
Re: starnge device
thank you pal
if you dont mind can upload these file to another upload sie
like media firePower consists not in being able to strike another but in being able to control oneself when anger arises
24-05-2012, 09:55 PM #6
Re: starnge device
http://www.mediafire.com/?mixu2n77h2kkl think ive done it!
24-05-2012, 09:57 PM #7
Re: starnge device
the site sayed
you dont have the right to enter this folder
please helpPower consists not in being able to strike another but in being able to control oneself when anger arises
24-05-2012, 10:08 PM #8
Re: starnge device
try now-i tried it and it worked
28-05-2012, 10:12 PM #9
Re: starnge device
thank you pal for your help
solvedPower consists not in being able to strike another but in being able to control oneself when anger arises
