    Nov 2011
    Canada
    79
    79
    13
    Carrier 2 1/2 Ton Air to Air HP performance.
    Hi every one,
    I just took some temperature and air flow readings at my indoor "A" coil. The vapour line temp
    seems high.
    Do these numbers look OK or do I have a problem?
    pilko
    Re: Carrier 2 1/2 Ton Air to Air HP performance.
    It may be but what is the refrigerant as the temperature on it's own does not relate to anything?
    Nov 2011
    Canada
    79
    79
    13
    Thanks for the response Brian.
    The refrigerant is R22.
    pilko
    Aug 2009
    New Zealand
    2,554
    Discharge does seem a little low, but this just could be down to losses, from comp and piping.
    Is frost on out door unit fairly/ice even when running
    But looks OK
