Thread: pump down the air-con unit
10-02-2012, 04:45 PM #1
Dear all,
To pump down the precision air-con unit,the liquid line shut-off valve need to close before compressr start or after compressor start? Which one is the correct method?
Please advise,thanks!
10-02-2012, 05:54 PM #2
Re: pump down the air-con unit
ksm , the correct method would be suction gauge ON< valved off< then its up to you ? have you done this before?= sedgy
10-02-2012, 09:40 PM #3
After comp start allow system to stabilise first.
11-02-2012, 03:14 AM #4
Thanks Stufus!
11-02-2012, 03:19 AM #5
Yes,Sedgy.if i close the valve before compressor start,the noisy sound came out from compressor valve when compressor start.Thanks!
11-02-2012, 11:05 AM #6
hi ksm , noisy ? then it looks like a internal problem with comp =sedgy.
