Thread: Hot to touch Compressor
14-01-2012, 09:44 PM #1
I have a four yr. old LG refrigerator that smells a bit hot and the compressor is hot to touch? Any explanations?
14-01-2012, 10:24 PM #2
Re: Hot to touch Compressor
Lost its gas, or blockage in the system
tonto33 is your man for domesticsIf the World did not Suck, We would all fall off !
15-01-2012, 05:45 PM #3
pot siezing or dirty condenser
15-01-2012, 08:58 PM #4
when you say comp is hot is it running?
is it off on internal overload or clixon?your only as good as your last job
19-01-2012, 12:19 AM #5
If there is a Fan motor to cool the Compressor, it may be stuck
19-01-2012, 08:29 AM #6
If the temperature inside the thing is correct
what you might be smelling is years of bacteria growing in the drain
pan on top of the comp.
If the temperature inside is high then the thing is on its way out and
somthing needs looking at by a professional.
So if the temp is ok try clean the drain tube and the little try at the
back that vapourises the waste drain water.
If the temp is wrong weigh up if it is worth the cost of repairing compared
to replacing.
taz
22-01-2012, 08:36 PM #7
compressor becoming weak or lack of gas can be repaired at reasonable price
22-01-2012, 10:14 PM #8
Don't do domestics often but I thought they always seem to have very high superheat so they don't sweat back. As a result of the compressor running hotter the moulded condensate tray was bolted on the top to evaparate the condensate.
