11-01-2012, 10:40 AM #1
fujitsu ASTA09JEC error codes & service manual
hi all,
i have a fujitsu ASTA09JEC indoor split unit with the following error code on the led's:
When the unit is turned on, the louvres open but nothing happens. The ‘Timer’ light flashes (red)
twice, waits 10 seconds, then flashes twice again.
Troubleshooting:
I have removed the unit from power for over an hour and also have power cycled the circuit that it is connected to, with no success.
just wondering if anyone has any suggestions or access to a service manual for this model?
any help would be great.
thanks,
shannon
11-01-2012, 01:05 PM #2
Re: fujitsu ASTA09JEC error codes & service manual
Similar Euro model
Signal error
http://www.fgeurofred.co.uk/content/Product_Data/Service/Service/ASYA09LGC%20-%20AOYR09LGC%20-%20Service.pdf
STUTool's ? check ! Condom's ? check !
13-01-2012, 12:21 AM #3
Reverse Signal Error (outdoor to indoor communication) This model has only one PCB in the outdoor unit but make sure fan motor and compressor test ok before changing board.
