Results 1 to 12 of 12
Thread: McQuay chiller
    Sep 2010
    Hungary
    40
    10
    McQuay chiller
    Hi! I have a problem with a McQuay screw chillers. There is an alarm on its screen.This is a service hour problem.How can I delete it?
    Apr 2006
    55
    1,908
    30
    Re: McQuay chiller
    Carry out the service needed
    Then
    Check one of your other posts enter service code and reset service
    Sep 2010
    Hungary
    40
    10
    Re: McQuay chiller
    Unfortunately I don't know the service code.If I known I wouldn't ask it
    Apr 2006
    55
    1,908
    30
    Re: McQuay chiller
    Here they are AGAIN then
    getting tired of answering and uploading to all your posts asking the same thing!
    Attached Files Attached Files
    Sep 2010
    Hungary
    40
    10
    Re: McQuay chiller
    Thank you for your help,you helped me a lot
    May 2009
    pakistan
    44
    10
    Re: McQuay chiller
    pls write ur chiller model and controller.
    rahamanrahaman's Avatar
    rahamanrahaman Guest
    Re: McQuay chiller
    mc quay als -229,microtech II controller
    manchester
    5,639
    Re: McQuay chiller
    this will cost u rep points!!!!
    Passwords
    Various menu functions are accessible or inaccessible, depending on the access level of the
    user, and the password they enter, if any. There are four access levels, including no password,
    Level 2, Level 4, and Level 6, with Level 2 having the highest level of access. Without
    entering a password, the user has access only to basic status menu items. Entering the Level 6
    password (5321) allows access to the Alarm Lists Menu, Quick Menu, and the View/Set Unit
    Menus group. Entering the Level 4 password (2526) allows similar access as Level 6 with the
    addition of the Commission Unit Menu, Manual Control, and Service Menu groups. Entering
    the Level 2 password (6363) allows similar access as Level 4 with the addition of the Unit
    Configuration Menu.
    Apr 2009
    israel
    778
    Re: McQuay chiller
    major rep points!!!
    sure hope machine survives this acces level
    best regards
    70
    4,703
    47
    Re: McQuay chiller
    Sorry IM.
    Apparently I have to spread points around before I can give more to you for a fine post.
    Jul 2007
    LIbya
    58
    72
    Re: McQuay chiller
    dear somo.
    why u dont asked MCQUAY for help.
    www.mcquay.com
    Apr 2009
    israel
    778
    Re: McQuay chiller
    Hi noori
    did you ever try to ask them for help??
    good luck
