    Dec 2010
    ireland
    Repair copeland scroll
    well all my friend has god forsaken nibe heat pump fitted 5 years ago and the copeland scroll is giving trouble....
    the inner pressure relief valve is stuck open and if it was a shop id tell him to change it but the same lad had alot of misfortune with his health in the last while and just after a kidney transplant and i am just wondering has anyone cut them open
    your help would be appriciated
    thanks
    padraic
    ireland
    1,453
    Re: Repair copeland scroll
    What model is she Paidraic?
    Prestons used to take them back for repair, maybe RSL might now that they are doing remanned compressors..
    Alec
    3,853
    This might be worth a go but it think they only do the bigger ones.
    http://www.jehall.com/news/article.jsp?newsid=31
    If he is a mate of yours could you get him a new one at cost? You can sometimes squeeze a bit more discount out of the wholesalers if they know its for a good cause.
    What model is it, voltage, refrigerant etc?
    Jon
    Jun 2009
    Lusk , Dublin
    1,115
    Get the Info off the comp and I'll see what sort of price I can swing one for , Is it for a fighter ?If so what model? I wouldn't bother decapitating anything under 30kw personally as it's a fooking pig of a job and a bit hit or miss.
    Stu
    Dec 2010
    ireland
    thanks for the replys
    its a nibe fighter model not to sure but will find out
    compressor is a copeland scroll zr48k3e-pfj-522 serial 0b6274687c
    it on 407c and 230v single phase
