Results 1 to 40 of 40
    Sep 2003
    pa
    Manuerop Compressors
    Have you fellas across the pond (at least EAST of NYC) had much success with the "MANEUROP" compressors from DANFOSS?
    I am considering the benefits as advertised for the Maneurop compressors to replace the Copelands that we now use on fruit cold storages here in PENNSYLVANIA. Copelands are just too expensive now. THANKS for insights.
    Jun 2005
    Stoke on Trent
    588
    Re: Manuerop Compressors
    I am not a big fan of Maneurop, I find them very noisy and the MT18 is possiblty the worse compressor that I have used. They are better on 3 phase than single phase.
    Apr 2001
    2,099
    27
    Ask me to chose between Copeland and Man
    Copeland wins hands down........every time
    Man is noisy..........the capacitors on fans fail every so often..
    it just kinda.........works odd..........
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Sep 2003
    pa
    Thanks for your reply's.
    We were trying to come up with an alternative hermetic compressor that we can use to comply with the 2010 EPA changeovers that we need to look forward to. Manuerop seems to be the only one advertising the ability to change oils, and, the same compressor will utilize the newer refrigerants. Most of our equipment uses R-22 which we need to phase out eventually. We will probably convert to R-410(a) with most of our 71/2 hsp and 10 hsp. equipment.
    Oct 2003
    5,630
    Scrolls from Benchmark (Bristol) seems very promissing.
    But if I had to chose between Bitzer or DWM, then I should chose without no doubt Bitzer. Very, very silent, no vibration, almost same price, ...
    Sep 2003
    ISRAEL
    72
    4,248
    Its a funny question,
    I love the Maneurop compressors and use them all the time when I need hermetics, only 3 phase though.
    Never had any problems with them.
    On the semi line, I agree with Peter, Bitzer comes first and then DWM.
    Chemi
    Aug 2001
    Gold Coast, Australia
    600
    28
    Hi John
    If you don't mind me asking, why 410a rather than 407c?
    Mar 2005
    58
    110
    Quote Originally Posted by john doersom
    We will probably convert to R-410(a) .
    Hi John,
    When using R410A you will need compressors with a MWP of 45 bar (on the HP side). Not all 'standard' compressors can handle this.
    Sep 2003
    pa
    Well, Thanks.
    We are used to the older hand-made 30yr. old equipment that I originally installed in the cold storage rooms during my 35 yrs. as an independent refrigeration contractor.
    Our equipment is mostly "KRAMER(tm) " product originally hand made in Trenton, N.J.
    I watched men hand drill holes in the mounting frames for the condenser and evap. during the assembly of same. After they had the return bends hand welded, they submurged the "coils" in a water tank. Then they applied 40,000 pounds of "water" hydraulic pressure thru the coils to expand the copper to the standard size of 1/2 in. od, or 3/8 in od.
    Out of due respect to those "older" craftsmen, I am keeping the equipment as OEM as possible. Currently we operate Copeland(tm) semi-hermetic compressors on the rooms that require CA (controlled atmosphere) . These are 10's and 20's, R-22. Originally we used R-502.
    I will probably keep the semi's on these rooms. However, we have a smaller room that uses only 7 1/2's.
    We hope to use this "smaller room" as a TEST BED for the MANEUROP's(tm).
    Our main supplier, here, is United Refrigeration, Phila. PA.
    They are allowing me to arrange a trip to Germany to visit with the MANUEROP factory people.
    The reason I will use 410(a) is that I MUST only stock only two refrigerants (I am allowed to say "*****" because DuPont Co. is my ALAMATER)
    So for RURAL Pennsylvania, agriculturally speaking, most of the older equipment will use *****(tm) R-22 orR- 410(a). I will do my part to keep the price of MILK affordable. EPA or no EPA!
    John C. Doersom
    Gettysburg, PA
    Oct 2004
    Scotland
    1,454
    Just to add
    I condemed one of them today! (mtz18ja5ve)
    and go get a cuppa
    5,667
    I like the Maneurop compressors and have just placed an order for 2 MT100 3 phase units to replace 2 Trane comps. Mans are quite forgiving with liquid floodback. OK, they are not really quiet but seem to run forever.
    Bitzer are not really AC compressors but of the ones I've worked on I'm very impressed. We are looking to replace a hermetic vertical screw (http://www.hartfordcompressors.com/) with a Bitzer on a Dunham Bush chiller.
    Sep 2003
    pa
    What was wrong with the compressor?
    We used to open them up and make mechanical repairs such as valves, internal Klixons(tm) etc. I am not sure, yet, if Manuerop will sell us parts for the hermetics. Just a few weeks ago, Copeland refused to sell us parts for a 3 hsp. R-22 hermetic compressor.
    I used to rebuild the hermetics when we couldn't get compressors from Copeland(tm), Tecumseh(tm) while I was in Australia. I wish now that I wouldn't have scrapped-out the "can opener" that I had for hermetics.
    Most of the time is is just minor repairs, bearings, valves, etc. for hermetics. I used to offer a 1 yrs. warranty on the rebuilds.
    I used to know an "off-shore" resource for parts for hermetics, but that was 25 yrs. ago.
    Oil return seems to be the biggest problem for the breakdown of hermetics. The new Copeland(tm) hermetics are all Mexican parts, even though the label says "Made in USA". Just had a new Copeland come through with NO oil in the compressor. There was only some assembly oil in the bottom of the POT.
    John Doersom
    Oct 2003
    5,630
    .....he new Copeland(tm) hermetics are all Mexican parts, even though the label says "Made in USA". Just had a new Copeland come through with NO oil in the compressor. There was only some assembly oil in the bottom of the POT.
    Those for the European market are coming from the Belgium plant in Welkenraedt
    Sep 2003
    pa
    It looks like we might being trying R417a as a replacement for R-22 in our existing equipment. First, I have to check with Copeland(tm) to see if they will approve for warranty issues.
    Thanks, everyone for your replies.
    John Doersom
    Gettysburg, PA
    Nov 2004
    uk
    77
    61
    Smile Re: Manuerop Compressors
    Quote Originally Posted by frank
    Hi Frank....just curious...what was the problem with the verical screw...we have cut a few open and flanged them...swapped bits and had some parts machined from new....mainly as an experiment and to "see inside"...we had to use massive flanges(made by Jerome) to satisfy insurance specs for pressure testing.
    We gave it up in the end as Dunham bush would only supply external parts ...their navy spec screws are already flanged but are expensive and difficult to get hold of....of all the ones we cut open(maybe eight..both twelves and fifteens)...there was only one burnout...all the rest were slide valve piston seals....we had some modified pistons and seals made to our own design which are still running after a few years.
    We have one compressor with the unloader seals down at the moment awaiting a clients order....they are a bit shy because of the cost which includes a crane lift in central London(Big bucks)...I am interested in your proposed replacement of a Hartford with a Bitzer...the latter being a much more reliable unit...the "O" ring seals are a bit prone to leakage in high temperature running conditions but they are semi's so easy to strip.Is there plenty of room to install the Bitzer on the unit you are exchanging on???....best regards...John.
    5,667
    It appears that the slider valve has jammed in and the screw is seized. Apparently, they have now changed the design to prevent this happening. That's according to John at DB. The machine was purring nicely then just stopped dead at 6.23 one saturday morning. (according to the Trend printout). I don't think we'll play about opening the hermetic and then trying to re-flange it.
    Once we remove the compressor I think there will be enough space to fit a Bitzer semi. The hard part is going to be getting the old one out and the new one in as it is on the forth floor and under partial cover.
    Obviously, we will need to re-jig the pipework, fit an oil seperator etc. but this seems preferable to buying a replacement Hartford vertical screw . We've been quoted £6.5K for the Hartford alone. As you said, at least with the Bitzer you can open them up for repair.
    Nov 2004
    uk
    77
    61
    I mistakenly thought that you were going to use a Bitzer screw Frank...hence my comment about the external "O" ring seals....with your comment about fitting an oil seperator I can see you are talking about a recip....will you attempt to reprogamme the D/B controller or will you change the controls altogether??
    Not getting wiser at the same rate as I am getting older??
    5,667
    We've changed the controls already.
    When the chillers were installed DB refused to commission properly because the architect had designed a cant louvred roof over them and they could not reject the discharge hot air. We got involved after everyone concerned with the project walked away under contract. The client obviously needed the chillers on line so we took over the maintenance and servicing.
    As DB would not give any back up or passwords the client got us to rip out all the DB controls and fit Trend. (we didn't do the control change over but worked with the Trend guys)
    Out of the 3 chillers, 2 continue to work fine but we lost the No.2 unit fairly early on in the project to this slider valve problem. With the recent weather, the client is now convinced that he has got to spend the money so we may very shortly be doing the change over. It was my idea to use the Bitzer (856m3/hr swept volume) as at least these comps were servicable. There is nothing we can do to the Hartford as it's hermetic.
    Nov 2004
    uk
    77
    61
    Well the very best of luck with the project....it sounds an interesting one...thats what makes this job so interesting isnt it??..when it is up and running maybe you could let us know how it all went?...best regards...John.
    Aug 2005
    Portland, Oregon, USA
    Quote Originally Posted by Aiyub
    Where I work, the preference is for Maneurop hermitic compressors, but for entire condensing units we gave up several years ago. The compressors still seem to be OK, but everything on the condensers, from fans to electrical box assembly, just hasn't been very good recently. The quality of the condenser assembly just seemed to go downhill over the course of several years.
    We had an entire batch of condenser units where the fans broke loose from the motor shaft. After that, we designed and put into production our own line of condensers with fans from another manufacturer, but still with the Maneurop compressor.
    On the other hand, our particular business tends to be large systems, and so we use the MT100 series compressors. Those are still made in Europe. The smaller compressors (MT18 and so forth) are apparently made "somewhere else" (according to a phone conversation with them). The difference in quality between those still made at the European plant and those made at the "somewhere else" facility might be why some us have very different opinions about these compressors.
    Sep 2005
    Granard, Ireland
    55
    43
    Well folks
    Any compressor but Maneurop compressors, no room for error ! just burnout. Replaced more blue bellies than any other.........
    Feb 2006
    ct
    11
    from ct. please dont waste your money on the blue.
    you'll be lucky if you see 5 years out it.
  23. #23
    Sep 2003
    ISRAEL
    72
    4,248
    Its all a matter of installation.
    I can show you many of them, working in hot conditions and still running fine after 15 years.
    Chemi
  24. #24
    Dec 2001
    nottingham
    96
    Have nothing but respect for Manuerop Compressors.
    Last forever as long as the installation is clean.
    Comes down to good installation procedures as usual.
  25. #25
    philippe's Avatar
    philippe Guest
    I'd add the precision that all the MT's from Man are made in the same plant in France.
    Phil.
  26. #26
    Sep 2005
    uk
    499
    Quote Originally Posted by philippe
    Phil.
    And then chopped in half by the likes of LH and others,where they build 1 out of the remaining bits of 4 dead ones and weld the 2 halves back together. The so called remanufactured units are prone to popping.
  27. #27
    philippe's Avatar
    philippe Guest
    Quote Originally Posted by slingblade
    Is it here a serious forum ? Or humor-destress posts ?
  28. #28
    Sep 2005
    uk
    499
    I do not understand your question. the fact of the matter is that in the UK it is possible, when faced with a dead maneurop, to buy a remanufactured unit which is nothing more than a combination of parts from several dead units. whilst this is cheaper than a new one it can have its drawbacks, rapid failure being the foremost. i have nothing against maneurop or indeed the french in general and this was not intended as "humor-destress post" whatever that may be. in fact Vive la France, and good luck in the 2010 world cup.
  29. #29
    Feb 2006
    derbyshire
    610
    i agree with the above apart from the football cause itay won by now,oooooooop.s,if there fitted correctly as anything on a new system fine,if you inherit a well troubled system which we all do its a case of how long is this gonner last then ! good thing is there easy to change,i think thats allways been there strong selling point.
  30. #30
    philippe's Avatar
    philippe Guest
    ...the fact of the matter is that in the UK it is possible, when faced with a dead maneurop, to buy a remanufactured unit which is nothing more than a combination of parts from several dead units.
    OK, I thought you were speaking about original Mans; not of hand-rebulit ones by some repairers. But in that case, take also car to PED !
    We're ashamed form the Mundial final result, we'd better remember the Brazil match . And one more final is not so bad
  31. #31
    Adelaide , Australia
    192
    Lightbulb Re: Manuerop Compressors
    Maneurop ? DONT DO IT !!
    Sounds like your supplier is in deep with the Maneurop boys .Trip to Germany sounds so tempting but its just a tin can in the end isnt it if they pay for you to go to Germany ultimately you will pay for the trip in the end ( in compressors ) , go for the Bulletproof Bitzer, Perhaps consult another Refrig Engineering Co. so you have honest opinions . Because as you can see by the replies most recommend Semi-Hermetic type compressors , anyone who recommends Maneurop is not being straight with you . If you are operating milk coolrooms R404 will do all your work , R410 is extremely high operating pressure . I only use R410 when it comes in those High Wall units that have a 5 year parts and labour warranty, they dont give that on real refrigeration applications , too many variables .
  32. #32
    Jul 2006
    Israel
    70
    12
    Hi , John , i do work in comercial a\c here in Israel , and we do replace some scroll comps from Trane units 12 and 10 HP , when one of the Trane comps goes i replace them with Maneurop , actually we got better results with them , also we use some Maneurop reciprocal of 5 and 6 ton , R22 , with the same good results , no conplains from me price wise or performance wise , good luck and all the best, Tzvi.
    P/s only 3 phase , no experience with single phase.
  33. #33
    Jul 2006
    k s a
    56
    7
    hai
    maneurop we can not compare with copeland
  34. #34
    Dec 2005
    Zagreb
    190
    Question Re: Manuerop Compressors
    Did someone work on Bitzer 8FC70,2.I have repeated troubles on that model.
    Renato
  35. #35
    May 2006
    netherlands
    58
    maneurops' internal thermal protection caused so much trouble to me. http://www.chez.com/fbetou/autopsie.htm
  36. #36
    Mar 2005
    58
    110
    The internal motor protection does not open itself. There is always a reason why it opens : temperature (overheating and indirectly overcurrent). It's easy to blame the compressor but mostly the reason is
    - inpropre system build up (soldering without N2, moisture in the system, poor oil return...)
    - poor maintenance (clouged condensor, bad defrost regulation, ...) ...
  37. #37
    Apr 2001
    2,099
    27
    Quote Originally Posted by donato
    Pity its in French
    Looks very intresting the article
  38. #38
    Aug 2005
    59
    Spend the extra and buy the Copeland. Their Scrolls are the best.
  39. #39
    May 2006
    Brisbane
    71
    48
    Its amazing how it went from maneurops to semis to screws.Everyone has wandered from the main question. Most compressors in the semi hermetic range are fairly good today. Good Installation and maintenance are the key be it Bitzer, Copeland, Frascold, or any other quality semis. Abuse anyone of them and they wont last. Maneurop or copeland hermetics will do the job at an initial saving on purchase price. By the time they need replacing we may be using co2 or some other environmentally more friendly refrigerant together with more energy efficient compressors. Why not just use R134A for now It works and is readily available especially due to its large use in auto a/c. Who knows what we will be using in a few years time that may render the semi obsolete. I can still remember when the belt drive was king in Australia. The Kelvinator open compressor made here was legendary for its longevity but could not outlast progress and technology.
  40. #40
    Dec 2004
    Australia
    52
    519
    [QUOTE=DeBI can still remember when the belt drive was king in Australia. The Kelvinator open compressor made here was legendary for its longevity but could not outlast progress and technology.[/QUOTE]
    I still see these on milk vats and some older pubs, not much goes wrong with them, slower reving than the Terry comps and far more reliable.
  1. refrigeration compressors
    By chabby in forum Heat Pumps
    Last Post: 21-07-2006, 09:52 PM
  2. Price Of Refrigeration Compressors
    By justin4236 in forum Supermarket Refrigeration
    Last Post: 08-09-2005, 01:38 PM
  3. Compressor's volume efficiency
    By John McGru in forum Fundamentals
    Last Post: 16-02-2004, 08:44 AM
