Thread: Plumb in LG Water dispenser
21-11-2011, 08:59 AM #1
Hi There
I have purchased an LG American style f/freezer and need to know how to plumb in the water supply for the dispenser and ice machine. There is no kit with it but I have seen the one I need to buy. My question is - Does it connect to the small pipe at the bottom of the fridge on the left as you look at it..? I have no instructions with the fridge. The serial number is GR L206CPQA
Chris.
21-11-2011, 10:08 AM #2
Re: Plumb in LG Water dispenser
G'day Chris. At the back of the fridge, at the bottom the right hand corner, there is a pipe that goes up. That is the water supply to ice/water dispenser. To the left of it is the connection for water inlet. If this is how i picture it on your fridge.. Make sure you have a water filter installed and the water pressure does not exceed recommended supply as per manual specifications.
21-11-2011, 10:15 AM #3
Thanks for the quick reply
Is the filter installed already in the fridge somewhere....?
21-11-2011, 10:31 AM #4
