    3,853
    Bristol 2 speed comps
    Hi Guys,
    Got a Bristol two speed compressor to fit in place of a single speed next week, its the same duty when run on high speed.
    Anyone know how these things are wired up, i believe the motors can work on either 2 or 4 poles depending on how its connected.
    Cheers Jon
    70
    4,702
    47
    Re: Bristol 2 speed comps
    Jon.
    Are you sure you don't mean Dual Voltage?
    Series A + BG series?
    Basically they are wired as stand alone or in tandem.
    I will email some details.
    Sep 2003
    ISRAEL
    72
    4,248
    3,853
    Cheers Guys! Looks like i have to link the low speed terminals together, and just power the high speed ones off the three phases.
    I've got a delay timer i shall fit too as i think the old one died due to cycling on the lp as its got a leak on the condenser.
    Jon
    70
    4,702
    47
    Hi Jon.
    The attached should help?
    Bristol do indeed recommend using a time delay to prevent comp short cycling.
    3,853
    Thanks Grizzly!
    I've got no excuse now not to go and fit it!
    I've got a IMO timer that i think i can wire into the CCH feed so that once the comp goes off it starts counting down till it will allow a restart, or i might be able to get a feed from the lp/hp switch if its one of those dual ones with the four connections.
    Cheers Jon
