Results 1 to 15 of 15
Threaded View
26-05-2011, 10:27 PM #4
Re: When does a 8 cylinder Recip become an Oil Pump?
MS.
You do yourself an injustice, you regularly captivate us with you descriptions of various equipment issues on your posts.
The largest was last year or was it 2 years ago, anyway a piston con-rod and liner was just 0.7kg under 50kg. What a mother that was.
Ranger.
Good point and one i would of likely come up with myself, if someone else had posted similar.
Only it is almost a year since this comp was serviced by me, but it has only recently been throwing it's oil!
Up until recently it was running fine, surely if I had done as you suggest it would of had issues from the outset?
Anyway it's mended now (Well almost!)
But has anyone had similar or can suggest another cause?
