    Jan 2009
    lleida
    47
    RS 45 (R-434-A) vs r-404-A? For R-22 phaseout?
    I'd like to know your opinions about replacement of R-22 system working (-10 ºC to 36ºC) to R-404-a or Rs 45.
    MY opinion is clear:
    1.-) We know for several years how R-404-a is working, (not the same for Rs 45).
    2.-) Big companies sell R-404-a for several years (not the same for Rs 45)
    3.-) Big manufacturers (Bitzer, Heatcraft, Danfoss... give performance data for their products with R-404-a (not the same for Rs-45).
    4.-) Everybody knows that glide for R-404-a is 0,9, Glide for Rs-45 its said that is 2,8 much bigger than 0,8 recognised by manufacturer...
    5.-) R-404-a price is better than Rs 45
    6.-) BUT, HERE COMES THE PROBLEM:
    You need much extra operations in order to achieve a correct phase out of R22 to R-404-a, than Rs-45.
    So, the offer is finally much expensive with R-404 a than with rs 45.
    So, What to do if my customer is only looking for the cheaper option?
    Thank you for giving me your opinions
    Re: RS 45 (R-434-A) vs r-404-A? For R-22 phaseout?
    What type of equipment are you looking to change?
    Jan 2009
    lleida
    47
    It's a fruit storage center, 4 Bitzer open units 6F.2 of 151 M3/H, with 10 rooms (10 Heatcraft NKT 4x6DB4L EVAPORATORS) and evaporative condenser. water defrost. and 10 danfoss TXV MODEL 55
    Jun 2001
    Gloucestershire
    13
    Why don't you use R422D from DuPont? To use R404A or RS45 you need to ensure pressure rating of system can cope with higher pressures of these refrigerants.
    Dec 2009
    Spain
    229
    if you recycle that R22, then the operation is not that expensive, as you have until end of 2014 to make a good use of it.
    regards,
    Nando.
    Jan 2009
    lleida
    47
    Hi ,
    I don't like replacement to R 422 D because of glide 4,5 K i s an important glide (i think), and i don't want to think i f this means a problem in the installation. I prefer to face a problem concerning pressure then glide...
    Hi Fri3Oil System, i agree with you about recycling, but in the two cases it's a "must" isn't it?
