Results 1 to 17 of 17
20-04-2011, 03:22 AM #1
Re: Fridge Problem..frost on suction line, and cooling is not good
the condenser temperature from compressor to filter goes like this..
%55-60 is REALLY HOT to hot.. %15 warm.. %20-15 ambient.. while the suction line near the compressor is as cold as the evaporator.. maybe colder.
Yeah he did change filter, and installed a valve.
I wasn't around all the time after he finished welding.. but I recall him talking about using the manifold to measure pressure after vacuuming, and after charging.
I don't recall seeing a vacuum though.. what I understood from the portions I observed is that he welded everything and installed the valve.. then used the running compressor to vacuum itself.. but that is what I put together from what I saw.. is that even possible?
20-04-2011, 08:34 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
It looks like it is overcharged.
Did he weighed charge, charged from glass cylinder
or charged by monitoring only suction pressure?
Last is recipe for overcharging.Last edited by nike123; 20-04-2011 at 10:02 AM.
