10-03-2011, 08:18 PM #1
Whirlpool K20 won't stop making ice!
Hi there, can anyone help me with a problem I have with a Whirpool K20 ice machine.
It won't cut out out when the bin is full and will carry on making ice unless I turn it off. I have tried replacing the bin thermostat as I thought that was the likely problem but it hasn't made any difference.
Please help it's driving me mad.
10-03-2011, 08:56 PM #2
Re: Whirlpool K20 won't stop making ice!
what position is the knob at and have you fitted the stat with the one nut or the two screw version
10-03-2011, 09:02 PM #3
pull a wire off the bin stat to see if it stops.if it runs then check the wiring loom,if it stops check ur stat connections
11-03-2011, 05:41 PM #4
Thanks guys, will try that on Monday and let you know the outcome.
