Thread: ISO68 oil / R422D
08-02-2011, 11:37 AM #1
ISO68 oil / R422D
I need to convert a chiller from R22 to R422D or equivalent. The chiller has a semi-hermetic screw on it which runs on ISO68 oil. I know this oil is designed for ammonia use but will I be ok converting this system to R422D?
05-03-2011, 11:07 PM #2
Re: ISO68 oil / R422D
Suggest you look up Duponts web site for Retrofit Information.
05-03-2011, 11:57 PM #3
Have recently inheritted a dairy cooling system that had been converted from R22 to R422D, i had to replace two solenoid valves due to the o rings leaking.
If and when i do any conversions from R22 in future i will be changing o rings or whole parts at the same time. Can't help much with your oil question...Mostly found in Oxfordshire, UK :)
06-03-2011, 03:42 AM #4
I can let you watch this may this help you about your question wish you good luck.
http://www.youtube.com/watch?v=p2KIcZSVUf4
06-03-2011, 08:57 AM #5
I agree with MS on this one, replacing all seals is a wise precaution. Having experience with the first wave of drop-in refrigerants, they did have a tendency to devour all forms of rubber in the system.
07-03-2011, 06:13 PM #6
First thing to do is to contact the compressor manufacturer and see what requirements he may have for using the blend and what oil to use in the compressor. Once you know th eoil and refrigerant, you need to check the other elastomers in the system.
Ken
30-04-2011, 05:34 AM #7
Its fine use the oil thats the biggest selling point of that blend is no oil change and no valve changing
Mop 29 / r422d
By Grizzly in forum RefrigerantsReplies: 4Last Post: 02-10-2010, 07:42 PM -
R22 to R422D Retrofit
By dantheguru in forum RefrigerantsReplies: 16Last Post: 21-07-2010, 11:35 AM -
R422d
By jjthefridge in forum Supermarket RefrigerationReplies: 2Last Post: 19-05-2010, 10:22 PM -
R422d
By chillled in forum Supermarket RefrigerationReplies: 7Last Post: 08-04-2009, 05:09 AM -
R422d ???????
By moshman in forum RefrigerantsReplies: 3Last Post: 08-08-2008, 07:25 PM
