Originally Posted by
hjcmb
Hi everybody, am new to the site, but wanted to join to tell you of an ASHP that i saw today that, i believe, is a game changer. Why? - because:
at A-19 it has a COP of 3.27 on a flow temp of 62c
at A0 it has a COP of 4.7 on a flow temp of 80c
at A+15 it has a COP of 6.83 on a flow temp of 81c
All models, there is a cmprehensive range from 4.5kw all the way up to 30kw off shelf, but will make bigger to order, have a db reading of 40 or below
All above figures confirmed as authentic by BSRIA
It uses a Sanyo compressor, Danfoss parts, but is not complex. I saw, and felt the 10kw and the 15kw in action, and they are phenomenal.
Now the real USP. They are totally retro fit friendly onto an existing radiator system, do not require or use an accumulator, just an exiting hot water tank, do not require back up, and get this, the 4.5kw is GBP3,007 installed, the 10kw is GBP3,815 installed, and the 30kw is GBP12,908 installed.
On those COP figures the ammortization is sub 3 years, even without the RHI.
To me a complete no-brainer.
