Results 1 to 50 of 68
Thread: Altherma flow temp issue
Threaded View
09-02-2011, 03:23 AM #11
Re: Altherma flow temp issue
Increasing the flow and decreasing the flow temperature, reduces the heat transfer to the concrete and thus to the air (the heat transfer properties of the water have little to do with the exchange process), however by increasing the flow you reduce the diff between the flow and return, and end up with a better overall even heat transfer to the concrete.
The energy relased by the concrete to the air will be even. With low flows and and high splits you tend to get concentrated heat areas
Controlling a compressor off suction line temp, or pressure
By desA in forum FundamentalsReplies: 13Last Post: 06-06-2010, 06:26 PM -
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
Residential A/C - Indoor air temp. off the chart?
By Bentus in forum Trouble ShootingReplies: 37Last Post: 09-07-2009, 03:10 PM -
Endless Freezer as Endless Cooler (10 door)
By herefishy in forum CommercialReplies: 95Last Post: 17-04-2002, 12:54 PM
